1997 Mercedes Benz 320e Sunroof
RICKYB1997
Electrical problem
1997 Mercedes Benz 320e 6 cyl Two Wheel Drive Automatic
I would like to know how to replace the Sunroof for this car. The cable is busted.
Feb 17, 2009 at 6:46 AM
GFIMOTORCARS
  • 673 POSTS
If you are replacing the sunroof tray assembly then you are looking at quite a job. Remove the sunvisors, upper control unit, grab handles. Head liner will be pulled down to access the sunroof tray. This assembly is held on by 10mm bolts all the way around. Drop the sunroof tray and gently remove the assembly. Pay attention to the sunroof drain tubesat the corners. If these get busted or mismounted they will cause interior water leaks on the vehicle. This really quite a job so let me know if you need any particulars.
Mar 31, 2009 at 4:44 PM
