1999 Mercedes Benz 300td Plastic casing on radiator
202,000 MILES • 4 CYL • 2WD • AUTOMATIC
RESONANCEMAN
Is it true that the '99 Mercedes 300 TD has a plastic casing? I was told that and that the radiator needs to be replaced. Is there a core value? What is an estimate for the radiator to be replaced? Thanks for any help.
Jul 13, 2009 at 9:59 AM
DR LOOT
  • 2,311 POSTS
That is correct, and if you were MacGyver. You would remove the radiator go to your local parts store purchase some epoxy. Designed especially to repair radiators (plastic) and go at it, and save yourself $500
Nov 26, 2009 at 10:56 AM
