1985 Mercedes Benz 300td smog
MAXMARGAR.COM
Engine Performance problem
1985 Mercedes Benz 300td Two Wheel Drive Automatic 150000 miles
exorst pipe bleck smog-only in low speed?
May 30, 2009 at 1:38 AM
  • 75,988 POSTS
Sounds like its running rich
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode
May 30, 2009 at 10:16 AM
