The armature on the alternator is caput. I am replacing it w. a reman alternator. Problem: One of the bolts holding the alternator in place is also holding an belt tension adjuster underneath its head. How do I get the tensioner to let go so I can remove that bolt? I have loosened the tensioner so it is no longer in the adjuster nut, but there is no extra space to separate the threaded rod from the tensioner adjuster nut. Thank you very much for your assistance and advice.
Sincerely,
Tom
Sincerely,
Tom
Dec 21, 2009 at 10:14 AM
