1979 Mercedes Benz 300td Rear Bearing Replacement
249,000 MILES • 6 CYL • 2WD • AUTOMATIC
SUZAN
What is the normal process for replacing the rear wheel bearings?
Mar 22, 2009 at 4:35 AM
DR LOOT
  • 2,311 POSTS
I have never seen a rear axle bearing go out in a Mercedes, are you sure you've diagnosed correctly? at any rate, to remove the rear axle bearings, you will have to remove the axle itself, once you have done that, there is 4 bolts on the lower control arm, once you have removed those the assembly with the bearings should come out.
Mar 25, 2009 at 12:42 PM
