1986 Mercedes Benz 300sl turbo
208,000 MILES • 6 CYL • 2WD • AUTOMATIC
MPMBSDL
I have a 86 sdl the turbo is not kicking in when I bought it I replaced a vacum line on it and it worked for a week then quit again. I changed the pressure switch and the switchover valve it still will not kick in. The turbo works but will not kick in.
Feb 23, 2009 at 10:34 AM
VLADGEISER
  • 66 POSTS
The turbo should be constantly spinning and providing boost pressure, check for pressure leaks in the intake, and check for pre-turbo exhaust leaks. Also check the waste gate or blow off valve to be sure it is not stuck open.
Mar 8, 2009 at 4:24 PM
