1993 Mercedes Benz 300se warm starts
1993 MERCEDES BENZ 300SE
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
THOSBRENNAN
Dear Sirs,
My engine will not start when the engine is warm. When given time to cool down it has no problem starting. Given our cool temperatures at this time of the year in Indiana, 15-20 minutes is all it takes to cool suficiently to start. A local mechanic wants to replace the "heat sensors" that he says are located at various places on the car. Can you help?
Dec 21, 2009 at 5:20 AM
MERLIN2021
  • 17,250 POSTS
INTERNAL LEAKAGE OF THE FUEL PRESSURE REGULATOR TECHNICAL SERVICE BULLETIN Reference Number(s): DTB 15/96-3; MB-NET 290, Date of Issue:  August 1, 1996 Related Ref Number(s): DTB 15/96-3; MB-NET 290 ARTICLE BEGINNING SUBJECT DEALER TECHNICAL BULLETIN 15/96 SERVICE INFORMATION 15/96-1 RECALLS AND SERVICE CAMPAIGNS: WHEN REPAIRING ANY CAR, ALWAYS CHECK THE VEHICLE MASTER INQUIRY FOR OPEN CAMPAIGNS 15/96-3 GROUP 07 - ENGINES M111, M104, M119 AND M120: For conditions of hard starting, engine running rough and/or surging at idle; we have found the cause to be internal leakage of the fuel pressure regulator, part no. 000 078 15 89 (Brumme) production code 06.95 and 12.95, through the membrane. To remedy this condition, replace the fuel pressure regulator with part no. 000 078 18 89 (Bosch). For warranty processing use Damage Code 0726204. MERCEDES-BENZ: Engines M111, M104, M119 and M120 GROUP: 07 - Mixture formation
This is an MB tech bulliten, have fuel system tested...
Dec 25, 2009 at 3:27 AM
