1993 Mercedes Benz 300se Upper control arm replacement
318,000 MILES • 6 CYL • 2WD • AUTOMATIC
VWCLEVENGER
How do I replace the front upper control arms?
Dec 21, 2008 at 7:23 AM
RACEFAN966
  • 5,029 POSTS
Ok first jack up the car and take off the wheel then you will see the upper control arm or wish bone. Now remove the shock and then seperate the ball joint from the upper wish bone and then remove the bolt that hold it to the frame and replace in reverse order and then have an alignment done.
Dec 22, 2008 at 3:51 AM
