1990 Mercedes Benz 300se Help Car won't start.
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
HOTSHOT427
I just purchased a 90 300se mercedes 3.0 with 150000 miles on it. had the car running for 10 minutes got in and put it in reverse and then drive and the minute i gave it gas it died and won't restart.
I have checked the following has new fuel pump and filter. It is getting fuel to all cylinders and spark injectors are good. checked all fuses and relays in fuse box. When i pull a spark plug it has fuel on it. what am i not checking.
Thanks.....
May 24, 2010 at 5:13 PM
  • 75,988 POSTS
Check for spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark?
May 24, 2010 at 9:22 PM
HOTSHOT427
Thanks rasmataz for the response.
I have checked for spark like you said.
however i am not getting a blue snapping spark but am getting a yellow orange spark.
Thanks..
May 25, 2010 at 1:02 AM
  • 75,988 POSTS
You have a weak ignition-check the coil primary and secondary resistances.
May 25, 2010 at 9:21 AM
