1987 Mercedes Benz 300se ELECTRIC COOLING FAN
1987 MERCEDES BENZ 300SE
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVID BRISLAND
WHERE CAN I FIND THE CENSOR SWITCH FOR THE ELECTRIC FAN
Aug 31, 2010 at 2:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if your merc has electric fan it will be controlled by a relay switch, should be in the engine compartment on the auxiliary relay panel
Aug 31, 2010 at 2:49 PM
DAVID BRISLAND
RElays are all OK it is the temperature switch I require
Sep 1, 2010 at 3:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
coolant temperature switch is on the left side of the engine, at the coolant intake housing.
Sep 1, 2010 at 7:31 AM
