1993 Mercedes Benz 300sd No coolining
1993 MERCEDES BENZ 300SD
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBSAINI
The heater works, The AC never comes on at all. I tried to jump the compressor but no luck. It takes 134,I added about 1 and half can of freon, Which it took it but the Compressor never comes on.Any help will be highly appreciated.
Thanks
Bob.
Jul 13, 2010 at 4:24 AM
DR LOOT
  • 2,311 POSTS
One can is insufficient to turn on the AC compressor if it is totally empty, you will need at least two, and you may have to jump a low pressure switch. The system will probably take 4 cans but you are wasting your time if you do not vacuum out of the system, that will also tell you if you have a leak, so you don't waste your free-on. This job requires several special tools you better take it into a professional
Jul 26, 2010 at 5:26 PM
