1993 Mercedes Benz 300sd Door Locks
1993 MERCEDES BENZ 300SD
WYLO761
Interior problem
1993 Mercedes Benz 300sd 6 cyl Two Wheel Drive Automatic
The driver door will not unlock with the fob -- other doors unlock OK. The lock moves up slightly, trying but doesnt extend far enough to unlock.
I tried to take the door panel off to see if there was an obstruction. I can get all the edges off by unsnapping the trees but something holds the middle of the door panel and I cant figure out how to get that loose.
Also the passenger door window extends too far in both directions making a clunking noise if you dont release the button soon enough. I would like to take that door panel off also. Can you help me?
Jun 9, 2010 at 6:37 AM
DR LOOT
  • 2,311 POSTS
you will have to find a hidden screws that are located on the armrest most likely hidden by some plastic caps, also you will have to remove the screw from the inside door handle that is most likely hidden behind a plastic cap.
Jun 15, 2010 at 7:25 PM
