1986 Mercedes Benz 300sd Fuel Pump not getting power
1986 MERCEDES BENZ 300SD
184,000 MILES • 6 CYL • 2WD • AUTOMATIC
SKIDOOMECHANIC
I have a 1986 300E that doesn't have 12 Volt to the fuel pump. There doesn't seem to be any fuses for it in the fuse panel under the hood. It doesn't say what the relays are for? Any idea were to check for a failure? Is there a relay or other fuse panel that I don't know about.
Nov 22, 2008 at 10:12 AM
DR LOOT
  • 2,311 POSTS
Yes there is, but you tell me you have a 300sd, and then you tell me you have a 300E, I cannot answer your question, until you tell me what kind of engine you have, and then I can help you
Mar 6, 2009 at 3:35 PM
