1985 Mercedes Benz 300sd Transmission acts up when fluid ge
1985 MERCEDES BENZ 300SD
MATT.P
Transmission problem
1985 Mercedes Benz 300sd Automatic
what would cause the transmission to work improperly when the trans fluid starts to warm up or get hot?
Apr 15, 2009 at 12:51 PM
  • 31,937 POSTS
Hi there,
there can be a number of things that can cause a problem like this, as the transmission heats up you may be getting internal pressure leaks, sticky valves, could be anything, best you get this inspected by a trans specialist before it develops into a more serious issue.
Mark (mhpautos)
Apr 15, 2009 at 11:40 PM
