1984 Mercedes Benz 300sd starter
235,000 MILES • 6 CYL • 2WD • AUTOMATIC
NIKNIK69
how do you install a starter for this car and do you have a diagram?
Jan 8, 2008 at 2:27 PM
  • 31,937 POSTS
Hi there,
Disconnect battery, remove solenoid wire and main battery wire from starter motor, undo 2 starter motor bolts, securing starter to bell housing and with draw, Access to there wire and bolts can be limited and tricky to do, if in doubt get your mechanic to do the job, as it is best to do on a hoist.
Mark (mhpautos)
Jan 8, 2008 at 2:34 PM
