1983 Mercedes Benz 300sd the signal lights dont work
1983 MERCEDES BENZ 300SD
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARCUS ROGERS
the signals dont work but the flashers do all of the fuses are good can you help with this problem
Jun 20, 2009 at 1:31 PM
DR LOOT
  • 2,311 POSTS
There is a relay for the turn signals,there is also a identical relay for the flashers, check your owner's manual and make sure you locate the relay for the turn signal, they are identical to the flasher, so that means you can swap them around and see if your turn signal work and vice versa your flashers do not.
Jul 25, 2009 at 9:08 AM
