1983 Mercedes Benz 300sd Brake pedal traveling to floor
1983 MERCEDES BENZ 300SD
180,199 MILES • 4 CYL • 2WD • AUTOMATIC
PUREENERGYZ
My 1983 mercedes benz 300sd brake pedal is traveling to the floor. I bled all four lines at the sametime with no change. Also the ignition key does not shut off the engine. Is this the master cylinder? The vacuum pump? Booster?
Aug 2, 2009 at 4:15 AM
  • 110,244 POSTS
I need to confirm something. WHen you say you bled all 4 brakes at the same time, do you mean you opened all bleeders at the same time?
One wheel should be done at a time starting at the wheel furthest away from the mastercylender and working to the closest. If that is what you did, chances are the master cylender is bad.
Aug 22, 2009 at 2:34 PM
