Interior problem
1982 Mercedes Benz 300sd Two Wheel Drive Automatic 134000 miles
When I bought my car, the vacuum door lock system was disconnected.. When I reconnected it, I found out why. When the driver door is locked, all of the other doors lock.. just as they are supposed to do.. THEN.. they unlock.. then they lock again.. then they unlock again.. and this lock/unlock cycle continues until the driver door is unlocked.. then the cycle stops in the unlock position... So.. I'm unable to lock the doors at all.. either from inside or from outside using the key.. I can disconnect the vacuum at the pump in the trunk, and manually lock/unlock each door but they are very stiff to operate..
Jan 4, 2010 at 3:23 AM
