1982 Mercedes Benz 300sd rear brake issues
1982 MERCEDES BENZ 300SD
CHLOEBROOOKE
Brakes problem
1982 Mercedes Benz 300sd Two Wheel Drive Automatic 200,00 miles
82 mercedes 300 sd turbo diesel- rear brakes- removal of rotors? after i've already romoved the rear disc brakes i still am having a challenge getting off the rotors. is there some trick to pulling off the rotors? they seem to be attched/ fused to the drive shaft. i removed the bolt that is revealed once the tire is off. now what?
Feb 10, 2008 at 9:05 AM
MERLIN2021
  • 17,250 POSTS
Use a good size ball peen hammer and wack it a few times, Hopefully you are replacing it...
Feb 10, 2008 at 9:12 AM
