1981 Mercedes Benz 300sd cranks but won't start
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
HIPPSAKAMO
I purged the lined with the plunger, no effect. I have noticed that if a disconnect the fuel line in, rifgt at the plastic fuel pre-filter, no fuel is pumped. I do not hear the fuel pump with the key on or when the car cranks. Shoud I hear it? Fuel does seem to pump out of the injector pump though. I suspect the fuel pump. Am i missing anything?
Aug 21, 2009 at 11:15 PM
  • 110,246 POSTS
It does sound like the fuel pump is weak or bad. Here is a how to for checking it. Check it out and let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Aug 22, 2009 at 2:28 PM
HIPPSAKAMO
thanks, where is the fuel pump? CHILTON SAYS IT IS IN LINE, under the left pass floor panal, but I DON'T see it there. is it in the fuel tank? in line next to the fuel tank?
Aug 23, 2009 at 11:20 AM
  • 110,246 POSTS
I just tried liiking i up with our online repair manual and the info isn't available. I believe the Chilton manual is correct. I don't think it's in the tank on your model.
Aug 24, 2009 at 8:00 AM
