1981 Mercedes Benz 300sd
FERRIELL
  • 1981 MERCEDES BENZ 300SD
  • 6 CYL
  • 180,000 MILES
I serviced the transmission. Started it up and started leaking around torque converter. Pulled apart and changed front seal. Put back togather and still leaks. What is wrong
Wednesday, October 8th, 2008 AT 11:23 PM
DR LOOT
  • 2,311 POSTS
Since the problem began after you service the transmission, it is probably the pan gasket, that is making it appear to be leaking, or the filler tube O-ring, recheck your job, make sure you got it together correctly.
Thursday, March 26th, 2009 AT 11:25 AM
