1980 Mercedes Benz 300sd Passenger door panel removel
1980 MERCEDES BENZ 300SD
MERCEDESPOOR
Interior problem
1980 Mercedes Benz 300sd 94000 miles
I need to know how to remove the front passenger side door panel to get to the window motor. thanks
Sep 29, 2009 at 9:48 AM
DR LOOT
  • 2,311 POSTS
you will find a screw behind the inside door latch, there will be another screw at the armrest, you will need a special tool, it's called a spoon, you can get that harbor freight to remove the clips without breaking them, that are all the way around the panel on the edges. You cannot see them only feel them.
Nov 27, 2009 at 12:16 AM
