1980 Mercedes Benz 300sd Oil coming through valve cover tub
1980 MERCEDES BENZ 300SD
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
CKUMELOS
This is actually a 300D, not an sd (I think).I guess the subject about sums it up. What would cause oil to come up through valve cover tube and how do we fix it?
Thanks,
Celeste Kumelos
Oct 6, 2008 at 6:52 AM
KHLOW2008
  • 41,814 POSTS
Hi ckumelos,
Thank you for the donation.
When engine blowby pressure is high, oil would be pushed out together with the ventilation gases.
The main cause would be worn piston rings and a clogged PCV.
To rectify the problem an engine rebuilt is required.
Oct 7, 2008 at 6:41 AM
CKUMELOS
Well, crap. Not worth the effort. I appreciate the help.
Oct 7, 2008 at 7:03 AM
KHLOW2008
  • 41,814 POSTS
You are welcomed.
Merc tends to have this problem for their older models.
Oct 7, 2008 at 7:14 AM
