1980 Mercedes Benz 300sd cranks over wont fire
ISLGU158
  • 1980 MERCEDES BENZ 300SD
Engine Cooling problem
1980 Mercedes Benz 300sd 6 cyl Two Wheel Drive Automatic
Car is a good running machine usually, the last day or two engine was unresponsive to gas pedal. Loss of power when near idle, delayed response time. Would a clogged turbo cause this. The fuel filters have not been serviced for some time. Im unsure of the plugs, Just to be sure there is no fuse that could cause these systems?
Sunday, October 24th, 2010 AT 12:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Is your check engine light on? If so what codes are stored? These are symptoms of a clogged catalytic converter but if engine light is on I would suggest getting the codes first, this should pinpoint the culprit and keep from wasting money guessing at the problem.
Tuesday, October 26th, 2010 AT 9:01 PM
