1979 Mercedes Benz 300sd Engine run on
1979 MERCEDES BENZ 300SD
174,000 MILES • 6 CYL • 2WD • AUTOMATIC
JSCHEARE
Just started happening recently in the past few weeks. When key is turned off, engine will continue to run for approx. 5-15 seconds before shutting down. Also, it has been starting very hard, even when it's warm. I can drive the car all day, shut it off and come back to it 15 minutes later, and it will crank and crank before starting. Is this a possible vacuum problem?
Mar 30, 2010 at 1:03 AM
DR LOOT
  • 2,311 POSTS
YES!!! you either have a vacuum leak, or your vacuum may needs rebuilding.
Apr 6, 2010 at 12:35 PM
