Fill the radiator up-start the car and look inside the opening is coolant squirling around if so keep it running and pinch of the upper radiator hose for a few secs and then let go did the coolant flow increase if so the water pump is doing its job
Jun 28, 2010 at 9:14 AM
KEOKI5150
MEMBER
1 POST
the radiator has no cap there is a seperate resivoir to fill with water thanks anyway guys
Jun 29, 2010 at 7:48 AM
TDHC13
MEMBER
HE MEANT THE RESERVIOR OPENING WHERE THE CAP IS LOCATED. SAME TEST SHOULD PRODUCE THE SAME RESULTS.
Jul 11, 2010 at 11:56 PM
