1990 Mercedes Benz 300e
HGREEN12
Electrical problem
1990 Mercedes Benz 300e 6 cyl Two Wheel Drive Automatic
alternator tested bad, bought another , tested good but when i turn on lights it would test bad. what are your thoughts?
Feb 12, 2009 at 12:34 AM
2CARPRO JACK
  • 11,533 POSTS
I have forwarded your link to our resident M/B expert. He should be with you shortly
Thanks for using 2CarPros.com
Feb 12, 2009 at 12:55 PM
GFIMOTORCARS
  • 673 POSTS
i just want to be sure we are clear about your test. So what you saying is when you place the vehicle under a load (lights on) the alternator is not increasing output to meet demand of more components. If this is the case you may have a faulty replacement alternator (this does happen) or a faulty voltage regulator within the alternator. The voltage regulator is a more common issue on MB vehicles. When you are testing this are you checking volts or amps? What are your readings like? Where are you testing, how do you have the meter hooked up? Also is the part a Bosch alternator or is it an aftermarket brand?
Feb 13, 2009 at 2:16 AM
