1988 Mercedes Benz 300e engine miss on idle and accelation
1988 MERCEDES BENZ 300E
309,000 MILES • 6 CYL • 2WD • AUTOMATIC
MYBENZE
engine starts with no problem.
Apr 22, 2009 at 9:59 PM
Do you have a check engine light and when was the last tune -up??
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Apr 22, 2009 at 10:35 PM
