1987 Mercedes Benz 300e Ignition is locked
GILBERTTHMS
Interior problem
1987 Mercedes Benz 300e 6 cyl Two Wheel Drive Automatic
I got it broke down but the ignition is locked and i can't get the key ot turn. I tried to use a self made release wire but the key needs to be at 1:00 and 7:00 but it won't turn, how do I get the lock cylinder out so I can change it?
I already donate for a question on now to change ignition but I don't get a anwser to this patr
May 29, 2010 at 9:59 AM
2CARPRO JACK
  • 11,533 POSTS
A standard piece of wire may not be strong enough to do it, i took the last lock cylinder to my friend that does M/B and he used a custom tool he made that will release it, not that that will help you much.There is a lever inside the housing that has to be depressed for the lock cylinder to turn so that it can be released.If the housing is out of the car, find a M/B shop in your area and see if you can talk one of the techs into swapping the lock tumbler for you for a couple bucks, most will do it since the assembly is already out of the vehicle
Jun 10, 2010 at 1:20 AM
