1986 Mercedes Benz 300e Auxiliary Fan Cooling Sensor
17,800 MILES • 6 CYL • 2WD • AUTOMATIC
BRADLEY123
Can anyone help me locate the Auxiliary Fan Cooling Sensor on my 1986 300E? I have the 6 cyl, automatic engine.
Mar 21, 2010 at 8:31 PM
  • 75,988 POSTS
Ive looked for that sensor the only thing popping up is the AC fan pre-resistor and aux fan relay for the high and low they all in the main fuse/relay panel
Mar 21, 2010 at 8:48 PM
MERC-OWNER
The sensor is on top of the cylinder head, it has three leads, others have only one or two points. It is the hot water termperature sensor. The Aux. fan senses the engine temperature from that sensor, and accordingly it engages whenever it needs to (when the engine heats up to about 110 C, e.g., when the air condition is on). If that termperature sensor is falty, the aux. fan will not go or it will go nonstop, even if the engine is cold. I hope this helps.
Apr 4, 2010 at 5:52 PM
