1984 Mercedes Benz 300dt oil coler lines
1984 MERCEDES BENZ 300DT
GREENCASTLE
Engine Cooling problem
1984 Mercedes Benz 300dt Two Wheel Drive Automatic 200,00 miles
I've got a 84 MB 300 turbo diesel. I'm trying to change the oil cooler lines and can't get the old one out. I've got them loose but unable to manipulate them out.
Mar 28, 2010 at 11:42 PM
DR LOOT
  • 2,311 POSTS
this is a very fun job, you will need to remove the engine mount, jack up the engine, be careful you do not break the fan shroud, get the engine as high as you can and then they will come out. Good luck.
Apr 6, 2010 at 12:33 PM
