1981 Mercedes Benz 300d Key ignition stuck
153,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRNSKATER
hello, i have a problem with my 81 mercedes-benz.
i can put the key in the switch. i can change from park to drive etc, without a problem. The steering wheel is locked and so is the key switch.
It has been giving me problems(it will stick for a moment but after shaking/ turning the steering will the car will start) for some time now(about 2 months). now it wont turn at all though.
my car is immoble and i need your help
What do i need to do?
thanks
Apr 28, 2010 at 7:00 AM
DR LOOT
  • 2,311 POSTS
have you tried lubricating the lock with some WD-40? do you have the spare backup key? the key may be worn out. If the key is showing signs of wear you will have to remove the passenger side door lock and go have a new key made.
Jun 15, 2010 at 6:43 PM
