1984 Mercedes Benz 300cd A/C - Center vents
1984 MERCEDES BENZ 300CD
20,000 MILES • 4 CYL • 2WD • AUTOMATIC
BAMFGATOR99
I have an '84 300CD turbo diesel, and a '94 300SL both have had recent work done this spring. No major repairs, just general up keep. The problem is that now neither center vents in both cars work. Both side vents work well. Is this a problem with a simple solution, or will this require more time in the shop? Thank you for your help.
Jun 19, 2009 at 4:56 PM
DR LOOT
  • 2,311 POSTS
it is to coincidental that both vehicles are suffering from the same problem, specially when they were both in the same shop. Check under your hood make sure all vacuum lines are connected, especially the ones that go inside the cabin.
Nov 28, 2009 at 1:39 AM
