1978 Mercedes Benz 300cd brake master cyl replacement
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
LAFITSME
I recently replaced the master cylinder on my 300cd when it began leaking fluid into the power assist, now it seems to be too tight, no pedal play. After I push it a couple times it seems to keep pressure on the brakes. Is there a way to adjust for this? The rad going into the master cylinder does not seem to have adjustment.
Aug 27, 2009 at 5:12 AM
DR LOOT
  • 2,311 POSTS
Did you remove the brake fluid from inside the brake booster before installing the new master? the rod that goes into the master cylinder is adjustable, also the brake pedal, underneath the dash is adjustable too.
Nov 28, 2009 at 1:25 AM
