2008 Mercedes Benz 300 Maintenance Service Indicator
CLIFF67
  • 2008 MERCEDES BENZ 300
Computer problem
2008 Mercedes Benz 300 Automatic
Our Vehicle show Maintenace B missed by 70 Days. How do I reset this without having to send to local Mercedes Benz dealership?
Thursday, August 26th, 2010 AT 3:58 PM
DR LOOT
  • 2,311 POSTS
MAINTENANCE SERVICE INDICATOR RESET - PROCEDURE 1
Step Adjust Additional Information
1Turn key in electronic ignition switch control unit to position "1"
2Press system selection button (S110s3) repeatedly until the basic display (mileage or temperature display) is shown in the multifunction display (A1p13)
3Briefly press trip odometer reset button (A1s3) 3 times. An acoustic signal can be heard and the voltage is shown in the multifunction display (A1p13).
4Press lower scroll forward/back button (S110s1)The "Service menu" appears in the multifunction display (A1p13).
5Press buttons + and -, setting of specific functions and volume control (S111s1) repeatedly and select "Confirmation" menu item
6Press lower system selection button (S110s3) to confirm."Confirmation" appears in the multifunction display (A1p13) and the menu item "Complete service" is highlighted.
7Press lower system selection button (S110s3) to confirm."Service confirmed" appears in the multifunction display (A1p13).
8Press the upper system selection button (S110s3) repeatedly until the "Service menu" is shown in the multifunction display (A1p13)
9Using the + and - buttons, setting of specific functions and volume control (S111s1) select the menu item "Special work"
10Press lower system selection button (S110s3) to confirm.
11Using the + and - buttons, setting of specific functions and volume control (S111s1), select menu item "Service 3"
12Press lower system selection button (S110s3) to confirm.
13Select the engine oil grade used by pressing the + and - buttons, setting of specific functions and volume control (S111s1)."Standard oil" or "Oil quality 229.5"
If only one oil quality is approved for the engine, oil selection is not possible.
14Press lower system selection button (S110s3) to confirm. The message "Position confirmed" appears in the multifunction display (A1p13).
15Press upper system selection button (S110s3) repeatedly until the basic display (mileage or temperature display) is shown in the multifunction display (A1p13)
16Turn key in electronic ignition switch control unit to position "0"
Sunday, October 31st, 2010 AT 11:41 AM
