1999 Mercedes Benz 280
GLORIAHOWARD
Engine Performance problem
1999 Mercedes Benz 280 6 cyl Four Wheel Drive Automatic 116.00 miles
engine vibrating when first start up and putting in drive
Oct 16, 2010 at 3:20 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Oct 16, 2010 at 3:49 PM
