how do I add transmission fluid?
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
CDOUGHERTY
I have figured out how to add everthing but tranny fluid to my car. Where is it located under the hood? Cant find where to add tranny fluid. and anything else you can tell me about why it may shift hard.
Mar 12, 2009 at 2:40 PM
GENERALGIBSON
i have an 88 MercBenz 260e. they both have the same engine with only a few minor changes from 87 to 88. you just need a funnel and pour it in where the tranny dipstick goes. i cant say for sure if this is the correct way to do it but i did it and ive put over 15,000 miles on it and did two big trips from ft.hood, texas to baltimore, md and then from baltimore,md to oklahoma city, ok. ive had no problems since then. its an automatic with 155,000 miles but the odometer never worked when i got the car 8 months ago. good luck. always research research and research some more.
BB00.40-P-0236-12A Automatic Transmission Fluids (ATF, Sheet 236.12)
Type
Aral Getriebeoel ATF M12
Fuchs Titan ATF 3353
Mobil ATF 3353
Shell ATF 3353
MB 236.12 ATF 3353 A001 989 45 03
This guide will show you how to check the fluid.
Cheers,
Jul 25, 2009 at 6:29 AM
