2005 Mercedes Benz 240d Door Malfunction
2005 MERCEDES BENZ 240D
45,000 MILES • 4 CYL • AWD • AUTOMATIC
ZANAIYA
My drivers door will only close if i use the key to lock it from the outside, although if i press the key alarm the other 3 doors will lock. When driving the "door open" ignites on my dashboard - showing the left drivers door open. However, the door is actually locked. What should I do
May 4, 2009 at 7:21 AM
DR LOOT
  • 2,311 POSTS
the reason the door will not lock is because the vehicle thinks it is open, "door open ignites on my dashboard - showing the left drivers door open" therefore causing the door actuator to malfunction the only thing I can think of that's causing the problem is the little button in the door that depress when you close the door is malfunctioning check that switch make sure it's good
May 30, 2009 at 4:20 AM
