Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
240d
Trouble Codes
P Codes (Powertrain)
P0400 - P0499
P0455
2004 Mercedes Benz 240d repair codes
2004 MERCEDES BENZ 240D
ASANFI
MEMBER
1 POST
what does mercedes repair codes p20988 and p0455 mean?
Mar 26, 2010 at 2:30 PM
BLUELIGHTNIN6
Experienced Mechanic
do you mean DTC P2098? if so, this code indicates a fault with the crash signal from the restraint systems control unit.
DTC P0455 indicates purge system has severe leak OR voltage supply for the tank pressure sensor is not correct.
Mar 26, 2010 at 6:21 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine — Oil Leak
Lock — Not Working
