I cant find the port to add freon?... is the R134 ok to use
do you have a diagram of where the port is?
Aug 9, 2010 at 8:38 AM
DR LOOT
✓Experienced Mechanic
they are very easy to find just follow your two hoses from the A/C compressor and you will find the port on each of the hoses, the big one is the low side and a small one is a high side, also inspect your compressor and you may find a port there
Sep 26, 2010 at 5:17 AM
