1999 Mercedes Benz 240d ABS and ESP lamps fail to fade af
1999 MERCEDES BENZ 240D
110 MILES • 6 CYL • 2WD • AUTOMATIC
AHMED SAKRAN
I have scanned the car using HHT DAS3 scanner.
The result was as follows:
Error Number C1140
I have changed The brake switch with no improvement.
Shall I check the wheel sensors? if the answer is yes, which side and front or rear?
Thank you
Jun 7, 2010 at 11:03 PM
DR LOOT
  • 2,311 POSTS
the sensors are magnetic and pick up metal shavings from the disk brakes I would start at the front right and work myself around the car
Jul 27, 2010 at 3:38 AM
