1981 Mercedes Benz 240d Replacement transmission
181,000 MILES • 4 CYL • 2WD • AUTOMATIC
JIMMYGREEN
Will Mercedes 300sd auto trans. bolt up and work on a 1981 240d? Local salvage yard says will work.??
Thanks
Jimmy
Feb 18, 2010 at 12:00 AM
DR LOOT
  • 2,311 POSTS
the Mercedes 300 & 240 have an aluminum plate behind the flex plate if that plate is identical it will work if not you will have to replace the aluminum plate so the transmission can both up.
Feb 26, 2010 at 1:59 PM
