1978 Mercedes Benz 240d Oil leaking into Vacuum Lines
1978 MERCEDES BENZ 240D
JAREDWALLACE
Electrical problem
1978 Mercedes Benz 240d Front Wheel Drive Automatic 240000 miles
I recently purchased a Mercedes 240D 1978. It has the whole enigine won't shut-off problem and some other vacuum problems because oil got in the system and blew some of the line attachments. I have located most of the leaks. Except I can not find where the oil leaked in from. I did have a pan leak so I'm assuming one of the tubes in that area has a leak and just vacuumed in some of the oil. Unfortunately I can't find any leaks that would do that. So I was wondering if there is another place oil could get into the lines? Thank you for any and all help.
Dec 27, 2009 at 2:57 AM
DR LOOT
  • 2,311 POSTS
The oil leak is coming internally from the vacuum pump that is on the left side of the engine contact your local European parts store and get a kit to rebuild it.
Feb 26, 2010 at 2:06 PM
