2005 Mercedes Benz 220cdi LIMP MODE SYMBLE ON DASH GEAR CHA
2005 MERCEDES BENZ 220CDI
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
GAR323ETH
CAR LACKS POWER GEAR CHANGE VERY SLOW ON CHANGE HAS HAD DIAGNOTIC CHECK AND THIS SHOWS VERIUS FAULTS AS PRESSURE DIFFERENTIAL SENSORPLOURSABILITY AND PARTICULATE FILTER FLOW MONITORINGAIR MASS THE ARE MASS IS TO SLOW CAN YOU PLEASE HELP WITH THIS FAULT
Jul 9, 2010 at 12:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
You may have a dirty or faulty Mass Airflow Sensor causing the low power and these codes to appear. You can remove the MAF sensor and try cleaning it then reinstall to see if it helped. Your vehicle's MAF sensor should be located on the intake manifold.
Jul 12, 2010 at 11:47 AM
