2001 Mercedes Benz 220cdi door mirror
54,000 MILES • 4 CYL • 2WD • AUTOMATIC
TNYMILS
intermittent door mirro extension and locking flash
signal
How does the mirror casing come off?
Feb 28, 2009 at 2:56 AM
DR LOOT
  • 2,311 POSTS
I don't think I'm understanding your question, but if you are trying to take the mirror apart, you will ruin it, that is a one piece unit, you will have to replace the whole thing.
Mar 25, 2009 at 11:48 AM
TNYMILS
many thanks for your reply. The only problem is that the mirror turn light do not come on although the front and back turn light are OK and this is only on the offside ... maybe the bulbs are gone or a wire is loose.
regards
Mar 25, 2009 at 10:00 PM
DR LOOT
  • 2,311 POSTS
sorry I misunderstood your question, are those aftermarket turn signals on the mirror? or are they factory? thay are probably LEDs, which I doubt they are burned out, sometimes if you check the loom, in between the doorjamb, you may find some damaged wires, the wires probably run through a rubber boot, peeled back the boot and examine the wiring loom, make sure no wires have been damaged, if they are aftermarket and somebody installed them, the wire that goes to the mirror, will be noticeable in the door jam, make sure you have power going to it.
Mar 26, 2009 at 3:32 AM
TNYMILS
Thanks for your advice. The mirror is factory fitted as original The lights are LEDS .. It probably is a wire loose, perhaps caused by the mirror retracting on park and I will have a closer look in daylight
Many thanks for your advice
Mar 26, 2009 at 7:46 AM
