1993 Mercedes Benz 190e Oil Light
1993 MERCEDES BENZ 190E
190,000 MILES • 4 CYL • 2WD • AUTOMATIC
22HRNET
  • 6 POSTS
oil light comes on & stays on for a little while & goes off. Oil level is full, oil is clean. Very little bit by the rubber seal @ the top of engine puddles up. is the oil light just for "oil level" if so, why is it coming on?
thanks
Jun 2, 2010 at 4:22 PM
Check the oil presssure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings
Jun 2, 2010 at 6:49 PM
