1993 Mercedes Benz 190e Fuel Filter location
1993 MERCEDES BENZ 190E
18,500 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTT.KNIGHT
Where is my fuel filter located in my 1993 Mercedes 190e? It is a UK spec car if that makes any difference.
Mar 20, 2009 at 9:40 AM
The fuel filter is located underneath the car, directly between the back seat doors; however, if you are jacking-up your car, it is much easier to reach it by using the drivers side.
Once you have the car leveraged, you will notice a cover/panel (note: the older the model, the more it will look like it is part of the car) with at lease two (2) screws (+/- 10/11 MM) holding the cover/panel in its place.
After you have removed the two (2) screws, the cover/panel will hang down - underneath is fuel filter and fuel pump and you will need a 14 MM open-ended wrench to remove the filter.
When removing, please be cautious, the filter will have excess gas left in it and it will spill.
Mar 20, 2009 at 11:59 PM
