1993 Mercedes Benz 190e change tramission filter
DEVILLEKIRK
Transmission problem
1993 Mercedes Benz 190e Two Wheel Drive Automatic 185000 miles
i change the transmission filter on a 1993 mercedes benze 190e 2.3 and a metal peice was in the pan.it looks like a bullet it is about a inch long. and about 3/8 inch round on one end and about a 1/4 inch round on the other.i change the filter because the transmission was slipping in 3rd and 4th gear.could this be the problem. i cant tell were the piece came out from.and do i need this piece.
Mar 29, 2009 at 12:42 AM
JAMES W.
  • 2,394 POSTS
I went through all the exploded views of the internals of your trans, 31 pages, and the only thing I saw that matched your description that could case your slipping problem and could make it's way into the pan was a push rod that closes the #2 band. The only way your're going to know for sure is to take it to a shop that does rebuilds on MB transmissions and ask them. Without actually see the part, I can only guess. Hope this helps.
Mar 29, 2009 at 12:39 PM
