1993 Mercedes Benz 190e Blown Top and water leak
1993 MERCEDES BENZ 190E
ROBERTNOG
Engine problem
1993 Mercedes Benz 190e Engine Size unknown Wheel Drive Type unknown Manual 150000 miles
Good day my car ran out of water at one point apparently without my knowledge and then all of a sudden stopped and wouldnt start..I tried putting water into it but the water just came straight out of a leak underneath..I found out after checking the dipstick that the water hadnt mixed with the oil..so now the question is if I buy the top gasket will the water leakage stop?? Thank you in advance
Feb 12, 2008 at 4:56 PM
2CARPRO JACK
  • 11,533 POSTS
If you locate the leak and repair the problem the leak should stop. I would also replace the thermostat.
Feb 12, 2008 at 11:33 PM
