1992 Mercedes Benz 190e cruise control
THUNDER454
1992 Mercedes Benz 190e 4 cyl Two Wheel Drive Automatic
the cruise slows to cuts out, if I hold accel, then it will cotinue to gain speed without kicking out. What do you think?
Apr 15, 2009 at 2:26 AM
16DIGITAL
It seems that the multi-purpose switch on the column is bad or has a connection problem like a shorted switch.
Be careful about playing with it or working it too hard. My Cruise rarely worked unless I repeatedly kept moving the switch arm/handle. After that it wore out or got much worse, and now will just take off at full throttle without warning. But I torqued mine too much. I just bump it down and back gently
if there is a problem. I guess I work on this next or find out if I can unhook it, currently replacing the ball joints tomorrow/tonight.
16digital
May 29, 2009 at 2:49 PM
